跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
Why does my laptop only last 2-3 minutes without a power adapter?
MacBook Air (13-inch, 2017)
Processor 1.8 GHz Intel Core i5
Memory 8 GB 1600 MHz DDR3
Graphics intel HD Graphics 6000 1536 MB
It’s been shutting down unexpectedly. At first, it was every 1 hour or so, than minutes, so on and so forth.
I’ve tried an SMC reboot, NVRAM, reinstalling macos. I did a hardware check (holding d on the keyboard when powering on). They said it could be the power adapter so i changed it, only for it to say that no issues were detected.
Battery condition, it says normal and with a cycle count of 731.
What could be the issue? Could the battery be faulty regardless of what the mac says?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Did the battery replacement solve the problem?
完成的
添加一条评论
1个答案
已选择的解决方案
Yep, it's a bad battery here. Here is parts and guide on how to replace battery. Guide is the same for 2013-2017 13” airs.
2015 年初 Macbook Air 13'' 电池更换
MacBook Air 13" (Late 2010-2017) Battery
An aftermarket replacement battery compatible with a MacBook Air 13" laptop.图片
产品
$69.99
这个答案有帮助吗?
得分 4
1条评论:
Thank you! I'll get a new battery as soon as i can.
完成的
添加一条评论
添加你的答案
Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 41
总计 586
