跳转到主内容
Garments that keep you warm on brisk days and dry on wet days. Repair difficulty ranges from simple tear patching to more complicated baffle repair.
20 个问题 查看全部
Can do you repair a rubber linning of a rain jacket?
The rubber linning of my rain jacket is peeling around the neck and shoulders. Can it be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I just ordered (HeatnBond Liquid Vinyl Water Proof and Stain Resistant Gel Coating, 8.68 oz) from Amazon and will try this on an old North Face rain jacket, has anyone tried this to "re-rubberize" the inside of a rain jacket?
完成的
添加一条评论
1个答案
Check first to see if the product is covered under a warranty. High performance products often are.
TLDR Probably not cost effective to repair otherwise.
The water shedding, “breathable“ membrane starts to de-laminate due to a combination of UV exposure and evaporated body oils. You might be able to remove the membrane but then restore with what exactly? Assuming it will effectively bond with the substrate, Spray on exterior silicone sealants can be utilized with varying success.
In either case, you will still not obtain the original performance, breathability, so you won't be as
comfortable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Caroline 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 1,245
