跳转到主内容
Known as the E39 , the 4th generation of the BMW 5 Series mid size sedan.
13 个问题 查看全部
Why is my car giving an excessive dicharge error?
I have a 2005 BMW 5-Series E60 that is draining the battery when it sits for days without use.
I have a relatively new battery.
I have disconnected the negative terminal of the battery, and I am pulling 3.3amps of current!
I have systematically removed every fuse in the trunk fuse panel, and the panel behind the glove box while monitoring the current. No change to the current draw with any fuse.
I have “re-registered” the battery using a code reader, and cleared all other errors.
I continue to get an “excessive discharge” error.
Are there any other (unfused) points of current draw I should be looking for?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try disconnecting the IBS (Intelligent Battery Sensor)
Here is a YouTube video Explaining the procedure.
https://www.google.com/url?sa=t&source=w...
这个答案有帮助吗?
得分 2
2条评论:
Brilliant! Worked like a champ, and I've been able to keep all codes cleared! Many thanks!
完成的
Glad that I could help.
Mike
完成的
添加一条评论
添加你的答案
Thomas Duffy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 76
