What type of adhesive tape is between the frame and digitizer?
Hello. Like a lot of people, my front and rear shells on my switch had cracked. Replacement of the front shell requires removing the digitizer and screen. I need some help on selecting an adhesive for putting the digitizer back into the replacement shell.
As you can see in this photo from the teardown, there are actually two different adhesives used. One is between the ditigizer and the screen which stops it from sliding around. (By the way, the photo does not depict the correct way to remove the digitizer, and I severed a ribbon cable as a result) This is the black 3-5mm wide foam adhesive that’s still adhered to the digitizer - I have this.
The other is the clear material that’s lifting off the plastic front shell. That’s the one I need. This actually isn’t a tape, it’s a thin plastic gasket coated with adhesive on both sides… it varies in width and is cut out where the speakers are. It’s also elongates much less than most tapes and is fairly stiff. I can’t find a replacement part anywhere so I’ll have to use a tape. Any suggestions for what tape to use?
Needs to be a very low build or the digitizer will not sit flush in the shell. Any foamed tapes definitely will not work. Thanks!
