跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No Modem Firmware but has IMEI
Customer came in with the problem that her phone didn’t turn on. I used a PSU and it jumped straight to 250ma after booting and stayed there. No logo or anything. Checked the battery connector voltage and it was only 0.5V. I changed the Tristar and Charging IC and the phone booted normally and didn’t show any sign of power leakage.
When I put the phone back together I saw that it was on searching instead of no SIM. That was for me the indication that something is wrong with the baseband.
I measured the surrounding capacitors and there was no shortage. Replaced the BBPMU and Crystal. Also reballed the Baseband chip. Powered on the phone and measured the capacitors and VCC main for voltage. VCC main has 4.2V and the rest is 0V
Could she have blown here baseband chip when she short her phone?
*#06# shows no IMEI, but when you look in settings/info it shows the IMEI but no modem firmware.
Anyone has encountered this problem before?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
That is no dought the problem of baseband chip,If the phones have not showing imei on *#06#,that is the fault.I solved it many times.Make this highlight pin jumper then putting BBCPU.
这个答案有帮助吗?
得分 0
2条评论:
Don`t forget to check BBPMU also and restore iPhone once.
完成的
@thegsmsolution late answer, but it didn't solve the problem. We decided to send it to china for cheaper labor cost. This started to look like a needle in a haystack. Swapping mainboards is cheaper in China than us looking for the problem. Hehheh
完成的
添加一条评论
添加你的答案
KWH 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 519
