跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
My new battery is not performing better than the old one. Why?
I’ve changed my battery and followed all procedures. I also calibrated it by letting it run down and charging it fully without interruption. My phone lasts even less than it did before I changed it out. What else can I do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Check the battery health with 3utools
这个答案有帮助吗?
得分 0
添加一条评论
Depends on the part, Did you get an ‘OEM’ grade battery for the replacement or the cheaper battery?
Knock off batteries can have a smaller capacity and might not perform like an OEM.
Defiantly check the specs on the battery with an app on the phone.
There are actual tools (Battery tester) that will give the information on the battery before install however they can be expensive.
The battery you have may also be faulty.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
THOMAS HESLIN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 29
