跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
No power when battery connected, but starts when battery disconnected
Hi everyone. First post of my own, but I have used this resource often.
Recently my girlfriend’s MacBook Pro shutdown mid-use and would not start again. The model is the late 2016 15” MacBook Pro Retina, with Touch Bar (A1707).
We tried SMC resets, PRAM and every key combination we could find. Nothing worked. So she took it in to one of the local authorized repair centres. She was told that it was the logic board and it will cost more than the price of a new Mac Mini to repair.
She took the laptop back. I’ve opened it up and disconnected the battery. The machine starts up if the battery is not connected. If I shutdown the machine and reconnect the battery, then it is stone dead, despite the power supply being plugged in.
This is repeatable. I’ve being tinkering disconnecting and reconnecting the battery connectors with the same result.
I’m hoping there are some more tweaks that I can try, otherwise I’m going to try find someone who does board level repairs.
Any ideas?
Update: Dan’s suspicion of the battery being faulty was spot-on. I found a battery from a local supplier. I installed it and the machine is up an running again without any issues.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Are you sure the battery is still good? Is the system charging the battery?
I would get a USB-C power meter to test the charger & the cable connection. Unlike MagSafe there are a few more connections between the charger and the system. One of the biggest issue is the version of cable (yes there are three different USB-C cables). The cable Apple gives you for the charger have heaver gaged wires for the power lines. Some cables have the same gaged wires across all of the lines and others are strictly data (no power). Here’s one tester Satechi USB-C Power Meter Tester. Plug in the cable at one end and test the line. Note the current, then flip the cable and meter the other way is the current flow the same when the meter is on the charger side of the connection?
IF the charger is working properly then I would see if a fresh battery solves things MacBook Pro 15" Retina (Late 2016-2017) Battery and here’s the guide 2016年末带 Touch Bar 的15寸 MacBook Pro 电池更换
MacBook Pro 15" Retina (Late 2016-2017) Battery图片
产品
$119.99
这个答案有帮助吗?
得分 3
2条评论:
Thanks Dan.
I'll get hold of a tester. I'm not in the US, so it'll take a while to get here. Or I'll have to try find a local supplier. The cable is the one that came with the MacBook new, but I won't rule out that it has gone bad.
I have my reservations about the condition of the battery. In the time between my original post and your reply I measured the voltage across the terminals in the batttery board (shown in Step 50 of the repair). I got 0 volts.
I'm going to try another cable/brick combo to see what happens.
Since iFixit can't ship batteries outside the US, I'll have to source a local supplier.
I appreciate the feedback. I'll revert once I've got a bit more info to share.
完成的
Thanks again Dan. I found a battery from a local supplier and everything is working perfectly. I'm still keen to try the USB tester to see if the charger/cable is faulty.
完成的
添加一条评论
添加你的答案
Graeme Hatley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,191
