跳转到主内容
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
51 个问题 查看全部
Screen flicker after microsoft logo then goes black.
was doing a battery replacement and after i got the screen off i wanted to check everything was ok so i booted it up and it would post the microsoft logo, then flicker some little white squares above the logo in a line. then goes black. Hooked up to a monitor with the mini display port and its running fine on there. does this mean the screen is broken, even tho it still shows the logo for a sec?
Update (06/05/2019)
also the touch screen even works when its a black screen, i can see my fingers interacting with stuff on the monitor hooked up through mini display port
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If the screen still exhibits some functionality, then perhaps it wasn’t re-attached properly? Try carefully re-attaching it one more time to see if there’s a difference.
这个答案有帮助吗?
得分 1
4条评论:
yes I have several times. no luck.
完成的
what do you think the odds are that its something in the display compared to the main board? I am thinking about ordering a new display but I dont wanna waste my money.
完成的
If you hooked up a monitor to the mini Display port and it worked fine from there, then most likely the problem is the display on the Surface Pro and not the motherboard.
完成的
ok, thanks for your help Dan.
完成的
添加一条评论
添加你的答案
Blake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 470
