跳转到主内容
iPhone是初代iPhone(中国又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,其他工具和焊接。
286 个问题 查看全部
问题已关闭
Force restore will not work; iTunes does not "see" phone
Following the directions on iFixit I can get my 1st Gen iPhone to display the connect to iTunes graphic, but when I connect it to my Mac iTunes does not "see" the iPhone, so I can't restore it. I tried two different USB ports and two different USB cables to be sure the issue wasn't the connection (and anyway both ports and cables work fine with my iPad).
Suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
Have you tried plugging it into a wall? Does it charge? If it doesn't your dock connector may be bad. If that is not the case I wouldn't know.
Hope it helps!
这个答案有帮助吗?
按维修分数 0
评论:
It charges fine.
Actually, having said that it doesn't appear to be charging consistently.. loose connection? Is that something I can replace, or is it on the logic board?
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 894
