Leaking from between the engine and gear box in Jeep Wagoneer?
leaking between engine and gear box. how do i fix it?
As oldturkey said, it really depends on what kind of fluid is leaking. If it is motor oil, the rear main seal (large circular seal between the crankshaft and engine block) is probably leaking. If you have a manual transmission, it might be manual transmission oil (which usually smells like sulfur) coming from the transmission input shaft seal that seals between the splined transmission input shaft and the transmission housing. If you have an automatic transmission, it might be ATF coming from the torque converter or the input shaft seal on the transmission. ATF is red in color and feels more slippery than normal motor oil. Unfortunately to access all of those components, you must remove the transmission. Companies make "stop leak" type products that sometimes help to slow small leaks for both the engine and transmission.
这个答案有帮助吗?
What might cause ATF to leak while the engine is running but stop when switching off the engine
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,683
3条评论
Is it leaking transmission fluid (what transmission does it have AT.MT)or engine oil or is it leaking antifreeze? Need a bit more detail. I am having a suspicion...;-)
由 oldturkey03 完成的
Hi I have a amarok 2.0tsi leaking water from between gear box and engine
由 ashley 完成的
Any help guys please
由 ashley 完成的
