MacBook Pro shuts down.
My MacBook Pro randomly started to shut down after boot up, maybe I have 2 second where it is on the login screen. But then it shuts down again, this happened after leaving it in the bathroom, so could it be water damage? I tried to hold shift control option but that doesn’t work. Can anyone help? Also, want to add on, if I try to log on in the short period of time it seems no keys can be pressed. Also no fans are running.
Update: MAC isn’t turning on at all now.
3条评论
I would start off getting a USB-C power meter Satechi USB-C Power Meter Tester So you can see what's happening. You could have a bad charger or using a bad or the wrong USB-C cord.
由 Dan 完成的
My charger was working fine the entire time, I just came back to it after finding it in the bathroom in about 4 hours, and it didn't turn on. It was at about 15% battery so shouldn't still turn on?
由 Theking101 完成的
Lets first get it out of the humid bathroom, you really don't want it in there at all. I would then let it charge up. As you can't tell you'll just need to let it sit for a good four hours (this is also a good reason for the USB-C power meter) As there is no charging indicator on charger or cord.
由 Dan 完成的
