No reverse on my Ez-Go PDS
I have an Ez-go PDS. My forward/reverse switch is a dash mount. When I select reverse, my beeper comes on but the cart starts to engage in reverse but doesn’t move. Forward works fine. Any suggestions?
If yours is like mine, under the seat is a large (~12” x ~8”) plastic cover, held on by 4 bolts. Upper 2 are easy, lower 2 aren’t. Inside are the power and reversing relays. There’s probably is a fuse inline with the reversing relay coil. The cart I work on has a big, manual switch not a relay. I’d look for fuses and listen for the relay engaging before pulling any covers etc.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,023
