Need to reset SMC before every boot
Bought Mac Mini on ebay. I7 16gb mem and two harddrives. one hardrive wasnt working. suspect ribbon connecting it.
problem is if i start it nothing will be on screen no chime just loud fan, if i reset SMC it will boot up fine.
Any clue why? how to fix that?
3条评论
If you can get into the onboard diagnostics, holding the D Key during start up. Apple messed up the firmware update so it may not work. If it does whats the error code/s you get?
If that fails, let's look at the sensors to see what's up there. Install TG Pro Take a snapshot of the main window post it here for us to see 在已经存在的问题里加入图片
由 Dan 完成的
Also wat i noticed i can get it running eventually. And let say i shut down. Come back after a while and once i get it to boot its in restart loop when loading mac os
由 Rafal Dronia 完成的
did diagnostic test. no issues.... doing extended now.
when system is crashing what i need to do is load it with SHIFT pressed and then delete contents of system library cache and then reset and will load.
由 Rafal Dronia 完成的
