跳转到主内容
修复你的物品
维修的权力
商店
问题已关闭
It just quit working. I'm not sure why.
I removed the hard drive from the case and put it in my desktop computer. The desktop couldn't find the hard drive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
What type of computer with what operating system did you put it into?
完成的
添加一条评论
1个回答
I'm going to assume this is about a PC, since most Macs don't have spare bays for 3.5" drives, and those that do would most likely see the drive. If it is a PC, then I would check the BIOS settings to make sure that the SATA port that you plugged the drive into is enabled.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 575
