跳转到主内容
No battery installed, Shuts down from randnomly.
So i have a macbook air 11” early 2014.
Before i took the battery out i could use it without any problems.
I removed the battery at apple store and at that same time they did the diagnostic test to see if everything is good. Since the battery was removed it did give a error on it. Everything else is good, but now when i use it sometimes it just randomly shuts off or i get logged out, i just need push the power button and log in and everything is still there. I’m sure that the charger is connect. Will buying a new battery solve the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Let’s take a look at that battery with a better tool. Please run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
这个答案有帮助吗?
得分 2
2条评论:
Do you want me to run coconut battery even though i dont have a battery installed?
完成的
No, put the battery back in to test it.
完成的
添加一条评论
添加你的答案
Anmol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 27
