What is the Home Button Paired With?
I have an iPhone 7+ with this motherboard with a broken display clip, (the thing where you plug your main display in.) I tried reassembling it with a new display and everything but unfortunately, not a hint of display was shown on the phone, but most of the chips are intact, so I tried plugging it on my PC and opened iTunes to see if it will be detected, and it did! I’m initially planning to buy a new motherboard for it for me to be able to use it as my daily driver but I had one problem:
I won’t be able to utilize all the security it can give if I can’t get the Touch ID to work, I’d really hate to use the assistive touch thing on it so I searched for potential solutions so that I can use the phone and give IOS a try for my own experience.
And then I had this theory: What if I transfer whatever chip/s the Home Button (Touch ID Module) was paired to on that old logic board to a new board? Would the Touch ID finally work?
2条评论
Nothing on the repair, but absolutely do not use any app, even temporally, that wants permission for Accessibility! Yes the buttons will work because they are activated from a different direction, but the producer, via the app, then knows every single keystroke you make, including your bank account numbers and your pin codes!
由 [deleted] 完成的
The finger print ID is paird with a chip on the MoBo, but other chips (IMEI is one of them) are paired with the same chip , so you would have to transfer many chips from the old mobo to the new one. So that is not a ciable option. Its better to find someone thst can replace the display connector on the old mobo.
由 Sohorca Adrian 完成的
