跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
702 个问题 查看全部
6-4 KitchenAid Dishwasher code
I have a Kitchenaid kdte104ess2. Seems like circulation pump is not working. Has run once or twice over the last twenty tries. Just fills and drains and sits till cycle over. No water through arms and throwing a 6-4 code. Would this code still come up for a bad circulation pump. I’ve checked float and all seems well there. Fills well and drains every time. Like I said no water through circulation pump but had kicked on once or twice so not sure if that’s bad or not
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I had this exact same problem. I replaced the circulation pump and got it working again. It's a big job to do, but worth the repair.
这个答案有帮助吗?
得分 2
添加一条评论
Here is a link to Sears parts direct. It has your error code listed and had a repair guide to fix it yourself.
https://www.searspartsdirect.com/dishwas...
这个答案有帮助吗?
得分 1
添加一条评论
Google kitchenaide dishwasher kdte 104ess2 and click on the Sears parts site then scroll down to error code 6-4 and a repair guide will come up so you can fix it yourself.
I have tried to link it here but was marked as spam for some reason.
这个答案有帮助吗?
得分 0
3条评论:
I’ve checked the error code on my sheet and said it is a float valve stuck open. My float lets in water and drains with no issue.
完成的
The repair guide may have you try resetting the power or other tips...
完成的
https://www.searspartsdirect.com/repair-...
Looks like it may be your circulation pump/motor.
There is a repair guide.
完成的
添加一条评论
添加你的答案
Ryan weeks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 80
总计 7,256
