跳转到主内容
A splash-proof, portable Bluetooth speaker from JBL, released September 2015.
Won't turn on before and after replace charging port
My friend’s JBL Pulse 2 had broken charging port. When you pressed the power button it still did flashed lights and gived the startup sound, but power LED wasn’t staying on. After dissasembly the speaker i found that chargin port was completely detached from the board. I replaced the charging port but there was no reaction on the speaker (should light up the leds on the right side. I opened the speaker more to get access to the mainboard and i measured the voltage of the battery, it was 3.2V only. I connected the battery to lab power supply and i charged it slowly by 100mA up to 4.2V as it should be. Still, the speaker only blinks with lights and gives the startup sound, not remains on. What may be the reason?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
tyhe problem i thinks was the mb because if has a overvoltage on board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amazon Seller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 105
