跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2027 个问题 查看全部
Home button not working after EARPIECE replacement
So, I was given an iPhone 7 to repair which presented no sound or mic during calls.
Tested speaker phone and voice memo. Mic was working, as was the speaker. Diagnosed a faulty earpiece speaker.
Replaced the earpiece. Re-attached the LCD and camera flexes. Put battery + LCD shield back on, same with camera shield. Closed up and secured bottim screws.
4 minute job. All screws in correct place. Didn’t touch home button.
Booted phone. Tested calls. All work fine, issue resolved.
But… TOUCH ID not working, and unresponsive Home button. WTF??!!
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Did you get an Error message. and did you disconect battery before you disconected anything else.
完成的
Yes to both. I disconnected the battery upon oprning the phone. I was presented with " TouchID not available" on first boot after earpiece replacement.
完成的
添加一条评论
2个回答
已选择的解决方案
“The iPhone 7/8 series have a very inconvenient bend on the Home Button flex. It’s really easy to tear the flex, either near the logic board connector or at the 90 degree bend before it sneaks underneath the LCD heat shield. You have to be careful when you lift the screen off the first time but also anytime the flexes are connected and you have the device open.
You will need to carefully inspect the flex to see if there is any damage. Magnification here will help.  Look for tears to the flex or any physical signs of damage. You should also check the connector to insure none of the pins are damage or that there isn’t any debris.”
This is a cloned answer and all credits should go to @refectio , just to be clear, but I believe it may apply to your issue.
这个答案有帮助吗?
得分 2
评论:
Checked home flex under scope -no tears, perfect condition.
Removed LCD (original) > checked connectors and board connections. No apparent damage.
完成的
@firebug1302 Next step then would be testing mesa pins in diode mode compared to a known good one, can't see any other way if you already tried hard reset and a restore.
完成的
添加一条评论
If you never removed the home button it may just need to be connected to Itunes. Not sure why but sometimes it needs to connect with itunes to clear the error.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charlie 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 142
