跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
424 个问题 查看全部
There is a little water damage in my phone , but the SIM card is fine
They say the iPhone XR can go into the water less than 30 minutes but I put it in for 30 seconds and the water got into my phone and I think I should not pay for a water damage repair because it saids it can go down in the water .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You put your phone in the water on purpose? Is it not working at all? Apple will not replace your phone based on their claims of water resistance. So, that’s not an option. If anything, I would open the phone and clean it good with alcohol. If you have access to a shop that has an ultrasonic cleaner, I would get them to remove the board and clean it. Hopefully there is just light corrosion causing whatever issues you are having with the phone that will be remedied by an ultrasonic cleaning.
这个答案有帮助吗?
得分 2
1条评论:
Oh my..let's see how the phone performs under water ?
完成的
添加一条评论
添加你的答案
Elany pontes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
