跳转到主内容
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
79 个问题 查看全部
Does someone know how to disassemble Philips PerfectCare GC9220 iron
Hello,
Does anyone know how to disassemble part 17 on page 4 of the service manual ?
https://www.manualslib.com/manual/953960...
One of the switches is not working anymore and I’d like to fix it.
thanks!
Benn
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @benoitmagicien
Well I guess
Most probably you need to get this
iFixit Opening Tool
The plastic seems to be clipped
take note on the red catch of the plastic when your remove
iFixit Opening Tool图片
产品
iFixit Opening Tool
这个答案有帮助吗?
得分 1
7条评论:
Hi,
Thanks for your input, actually, the red catch I can get out easily, the whole back part is also not attached, so those things are not plastic catches.
Basically, i can lift the front and the back, but it's blocked by something (probably plastic catches) around the whole in the middle. And I can't get to the screws you circles without removing part 17 first...
完成的
Hi @benoitmagicien
work slowly, if you have a opener, that's great, else if have a used credit card, can slot in and try removing it, but slow and steady.
If you feel there are a lot of resistance or suspect there is a screw, slow down or stop.
完成的
There is a lot of resistance, but there is no screw to access.
Here's what it looks like from the top :
https://images-eu.ssl-images-amazon.com/...
完成的
able to take out 18 and part 13 first?
完成的
That seems like a very very good idea !!
I'll try that first thing when I get home and keep you posted !
Thanks !!!!
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Benoît DESTRUBÉ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 1,209
