New iPad 2 OEM battery causes continuous reboots?
I've replaced my iPad 2 battery with an OEM battery because I broke the battery controller board on the original battery.
The new OEM battery actually seems to work and charge perfectly but it seems to be making the iPad unstable since it reboots every 2-4 minutes even when connected to power.
I've had the logic board moved over to another iPad 2 3G and there it works perfectly, so the problem doesn't seem to be the logic board.
Does anyone have an idea for a fix that doesn't mean getting a new battery?
Update: The problem must be the design of the OEM batteries - does anyone know where to get actual original iPad 2 batteries or used ones?
Did you ever find a solution for your problem? I messed up an ipad 2 battery trying to move it to a new back cover, ordered a new non-original one and have the exact same problem!
由 Fixandinstall 完成的
Old question, but I thought I'd give you all an update.
I managed to get an original battery from a water-damaged iPad and I doubt it's possible to fix the faulty OEM batteries.
由 Anders 完成的
