跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
128 个问题 查看全部
Why is my external hard drive making this weird noise & not showing up
Why does my external hard drive keep making this weird noise when it is plugged in either my laptop or PC, both are Windows.
It was working the other day now it won't
Please help.
Update (05/20/2019)
I have a recording of the noise if that would be better
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
You say "It was working the other day now it won't". Did you drop it?
I'm not entirely clear if your external drive still shows up in Windows, inspite of the noise.
If it does and files show up copy the important files from it immediately.
完成的
yes I dropped it...
now I can see the drive, bt can't open...
完成的
@ASUTOSH SAHU
Drive mosty likely physically damaged. But there is always the possibilty that an application like "Spinrite" by Steve Gibson might recover it.
完成的
添加一条评论
2个答案
已选择的解决方案
It sounds like part of the drive has failed. Either the bearings in the motor, the heads crashed, or such.
  • Does the weird noise sound like one or a combination of these?:
  • Grinding
  • Chirping
  • Rattling
  • Screeching
  • Loud vibration
If so, it’s probably failed. If the data is worth sending the drive for recovery, do take note that the more you attempt to use it the less likely anyone can recover the data.
这个答案有帮助吗?
得分 2
2条评论:
Does 4his mean it is done for good
完成的
It is highly likely that it failed. Data recovery can be expensive, so I would recommend cutting losses and getting a new drive. If the data to be recovered is more valuable to you than the cost of data recovery services, then go for it. Just note that no one can guarantee that they can recover the data and most will charge you for even trying.
完成的
添加一条评论
It does sound like the drive has failed. If you need the data on it you’ll need to send the drive into a data recovery service. Hopefully they can recover it.
If you are moving your drive around you might want to look at getting a SSD drive as they are more rugged. HDD’s don’t like being moved while they are running.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lewis potts 将永远感激不已
浏览统计数据:
过去 24 小时: 14
过去 7 天: 102
过去 30 天: 471
总计 11,756
