跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Microphone, earpiece speaker, rear camera and a boot loop
A couple days ago my personal iphone 7 plus started malfunctioning severely.
First, the mic stopped working during a phone call, then the earpiece speaker refused to work. Tried powering it off, and doing a hard reset. The result was a boot-looping device for the next 30 minutes. It finally stopped boot looping, and i was returned to my home screen. I afterwards discovered that the rear camera no longer actually takes pictures. I can see images on the screen, but pressing the button results in no saved picture no matter what i do. The front (selfie camera) does actually take pictures and saves them, but you have to hold still for about 15 seconds after pressing the button.
Has anyone seen this before? If so is there a known issue? Is there a part i can replace that can remedy this? i have not tried a restore yet, that is my next step, but not until i get a new phone. Until then i am left with a device that cannot make or receive phone calls.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
All these symptoms point to iPhone 7 audio IC disease. Check to see if voice memo works. If not you will need to run a jumper under the audio chip.
这个答案有帮助吗?
得分 2
1条评论:
oh no. hopefully that isn't the case. will report back when ive had a chance to try other remedies
完成的
添加一条评论
最有帮助的答案
First remove the front camera flex and check,hope you got all answer after doing that.
这个答案有帮助吗?
得分 2
1条评论:
thank you i will give that a shot
完成的
添加一条评论
添加你的答案
Chris k 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 107
