跳转到主内容
Repair and disassembly guides for Asus Windows tablets.
120 个问题 查看全部
Blinking battery symbol after wet
I accidentally got water on my ASUS tablet model K008. I left it alone for a while in rice, hoping to draw out the water. It wouldnt turn on so I connected it to the charger. Now it just blinks with the battery symbol for a while. What can I do to fix it? (I have no tools, I would need to buy them)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First, rice is a myth. While the theory makes sense, it just creates a huge mess inside the device. If the device was fully submersed in water then the battery likely needs to be replaced. It’s also possible the screen needs to be replaced as well. These are the two common things that needs to be replaced in water damaged devices.
What you really need to do is get the device opened up and get any water out of the device and clean up any corrosion that may be starting. If you don’t have the skills or tools to do so take it to a local repair shop that does water damage recovery work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 61
