Getting an audio port from the internal speaker of a projector?
I’m working on repairing a bad LCD panel on my projector and thought since I had it opened and waiting for part that I could add an audio line-out.
(The speaker is attached by three wires to a plug that goes in the main board)
I’m afraid that the power sent to the speakers may be too much for something connected to it by a 3.5mm female plug. . . .
How would I safely wire a connection from the wires that come from the main board to the 5w speaker.
The technical sheet on the projector says it’s a 2W speaker. I assume that that’s the maximum power that goes to it although the speaker is marked as a 5W model?
Should I add capacitor to connector?
Any advice on this would be helpful.
Thank you.
EDIT**
To clarify my question and intent.
I have a audio wires going from a main board to a 2W speaker.
I want to desolder the wires from the speaker to a female 3.5mm plug.
Do I need to reduce the volts (or total ohms) that go into the plug so that anything connected to isn’t incredibly loud or completely blown out?
