跳转到主内容
无线连接并控制您的苹果电脑。
89 个问题 查看全部
How to get the command key into place.
Are there any good guides on how to snap back the left command key back on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
By examining the underside of the key cap—assuming it is not damaged*— you should be able to tell which side would be inserted into the space first, then the last movement is just to press down to “snap’ into place. Usually one end slides in place first “down and to the left”. If it looks damaged on underside, you may need a replacement.
*If you can’t tell if it’s damaged, pop off another one and check it for structure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TheYootz Media Group 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 98
