跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
After screen replacment works then stops after a few weeks.
I have a iphone 6, i replaced the screen and it worked for a while then it stopped working. i heard it could be because when you put the cables and put the screen back on you have to bend them a special way. When i get the new screen(Again) Can somebody tell me how to bend them the special way if thtas true or how to fix my old one, Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Lol I love these bend them the special way things lol
When u say it stopped working how did it stop working was it dropped… how high was the drop
Replace the screen put the metal plate back on with its screws dont mix up the screw order and it should be ok
When it's working go slap the person who told u to bend it the special way in the face :)
How did it stop working? Blank screen, fuzzy colours, no touch etc
这个答案有帮助吗?
得分 0
8条评论:
Lol ok, So i left it on the charger one night and the next day it wouldn’t work. The back light was on but no display. After it was off for a while i removed the battery. It was so old it couldn’t even hold the phone on for a minute. Sorry this isn't answerd i accidently did that...
完成的
So was the phone on a good quality charger and do u get signs now the phone is on and working and just the screen isn't??? Eg does it vibrate does it ring etc
完成的
When I had the battery in before I tossed it the LCD lit up so I could tell it was on but no os seen. Does it madder how I had the cables when I closed it up?
完成的
As long as ur not damaging the cables and crushing them in any way and the screws are in the right holes and u havent caused long screw damage it shouldnt matter... u can have damaged screens where the flex is damaged and bending it can cause it to stop working but if its been working for a while it's not likely the case... common thing for screen problems a few weeks later are usually a broken screen or shorted backlight caused by the sticker covering the backlight solder point being out of place and shorting against the metal plate.
完成的
So what should I do?
完成的
显示更多的3条评论
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 75
