跳转到主内容
修复你的物品
维修的权力
商店
The current line of iPod touch comprises seven (7) different generations.
3453 个问题 查看全部
iPod fell in water. Any hope?
My iPod 6th generation fell in water when I found it the screen was still on and had power but I didn’t turn it off immediately. The ipod turned off by itself later. I wiped all water from it and carried it with me for about 1 hour and I noticed the iPod logo show up and then slowly fade away. IT is sitting in rice right now but wont turn on if I plugged it in. If there is a short circuit……..Can it still be repaired and fixed? Possibly changing the battery or parts? Is there any hope at all…..its the newest ipod touch model and fairly small with compacted parts. Please somebody give me hope and tell its not dead!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
1个回答
Rice won't work and often causes more harm than good; rice flour (caused by friction between the grains) gets inside the phone and hardens around the components, plus at best rice is only going to absorb about 7-10% of the water at most.
Best results: Open it up, remove the display, disconnect and remove the battery. Give everything else a bath in 99% isopropyl alcohol; this will displace the water that's still inside. If you have access to a sonic cleaner (e.g., a jewelry cleaner), even better. Blow out most of the alcohol with compressed/canned air and let it dry for maybe an hour in a dehydrator if you have one, otherwise in front of a fan overnight. In the morning reassemble with a new battery and (most likely) a new display.
这个答案有帮助吗?
得分 0
评论:
Any hope for the data? I had pictures on there tons that are rare. if the battery gets replaced will the data still be there?
完成的
Data is not stored in the battery so, yes, if the battery gets replaced the data will still be there. (Assuming the iPod is otherwise functional.)
完成的
添加一条评论
添加你的答案
CreativeJustice 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 31
