跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1696 个问题 查看全部
Eject button is not working, I can eject from system & reinsert disks
Hello everyone, i have a very weird problem that got me confused and frustrated , after opening my PS4 for cleaning and applying new thermal paste (I did it twice before with no problem), i placed everything back and everything thing works fine except for the eject button, i can insert disks normally and eject it using the software or the emergency screw, only the touch button doesn’t work i’m sure its not the eject button, rubber spacer or the silver pin on the housing because i tried to touch the Copper pin on the drive board but it doesn’t respond or beep..
Any ideas!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Is this the model where it uses your finger touch to eject and power on the PS4?
If yes the chances are the metal spring used to contact the eject button to the eject board is probably bent the wrong way. If it’s not broken you can just bend it back to it’s original position:
这个答案有帮助吗?
得分 1
3条评论:
@benjamen50 yes it is my model ( CUH-1003A ), but it’s not the case, i already tried to reposition it, also I tried to remove the lower case and touch the copper pad on the board directly and nothing happened..!!
完成的
How's the cable between the eject daughterboard and the main board? Sometimes it might not be plugged in fully on both sides or the cable / connector on either side being damaged.
完成的
If you mean the main cable that connects the blue ray drive to the entire motherboard yes it’s connected but i have some suspicions that its partly damaged and I already ordered one, but i was wondering which one of the three is the eject ribbon cable ?
完成的
添加一条评论
添加你的答案
kamal helmy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 336
