跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Touch ID not working after battery swap
Alrighty, so I had done a battery swap on this phone. Before hand, everything worked and I had checked everything. For the battery swap, I took the screen off just to make sure I don’t accidentally rip the ribbon cables. When I got done, I put everything together and the Touch ID wouldn’t work. What’s weird is the home button would work. I tried reconnecting the screen hoping the connections were off but that didn’t fix anything. I went to the extent of taking the home button off and checking to see if there were any micro tears. I couldn’t see anything that was wrong so I reconnected everything and again, the Touch ID wouldn’t work but the home button would work. I’m at a lost of what could have gone wrong. If anyone has any ideas, please let me know.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Well usually it's either dislodged or missing components near screen connector or the screen got somehow damaged.
Definitely need to try another screen as this is a common fault that is usually solved by a screen replacement.
这个答案有帮助吗?
得分 4
1条评论:
I put a new screen on and it had fixed it. Ill look around the screen connection to see if there is something missing. Thank you!
完成的
添加一条评论
What happens when you go to settings and try to set touch ID? I find it really weird that touch ID stopped working but the home button function still works.
这个答案有帮助吗?
得分 2
3条评论:
I backed up the phone and did a factory reset. When setting it up it prompts you to use the Touch ID and I would try to put my finger print in. It wouldn’t read my finger but if I pressed too hard it would tell me that I need to press softer. I haven’t tried a new screen but I will try that, I just find it really odd because it is the factory screen and hasn’t been tampered with.
完成的
Update: I put a new screen on it and the Touch ID is now working. Does anyone know why the original screen would eliminate the Touch ID?
完成的
It is not the fault of the screen. There was likely damage to the ribbon cable that you could not see. I have had this same issue with a replacement 7 Plus screen. I suspect the screen was returned but then tested by the seller and showed the LCD/Digitizer were good so they resold it to me. Something was likely pulled or twisted just a tiny bit too much and cause unseen damage.
完成的
添加一条评论
Here are my thoughts looking through what other have posted. I ran into an issue where I was working on an iPhone 7 and tore the home button extender cable because the screen slipped on me as I was opening the device. It’s possible that’s what happened here. Was the screen an original part from Apple or was it a replacement? It’s possible that if it was an aftermarket part, there could have been some damaged done already and reopening the device finished it off.
A few other thoughts are pinched cables can sometime cause odd things to happen but it sounds like a new screen solved the problem. There is a lot of room to play with the connectors on the screen on this model but you always need to be aware of how much tension you put on the cables as well.
这个答案有帮助吗?
得分 1
1条评论:
I believe it was a bent/pinched cable. The screen that was on it was an Apple screen. I put on an aftermarket one and it had fixed it. Thank you for the insight though!
完成的
添加一条评论
Touch flex can be broken while open the phones or possible connector damage,You have to check the screw hole might me problem by long screw.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ely Sellin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 163
