跳转到主内容
修复你的物品
维修的权力
商店
Repair and support information for HP Laptops, designed for home and home office use.
767 个问题 查看全部
HP pavilion x360 15 CroXXX phantom ethernet connection
My laptop doesn’t even have an ethernet port and its showing an ethernet connection. It has been causing problems so I need this gone. Anyone have this issue before and know how to fix it?
Update (05/16/2019)
Here are the devices that show in device manager
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Hi @connor2003
How are you?
some things you can try.....
updating the computer BIOS,
what do you see in device manager on network adapters?
完成的
I posted an update, please check it out.
完成的
are you able to uninstall the Realtek usb gbe family controller from device manager?
if you are not using it, consider removing the drivers by checking it when you remove the device from device manager.
完成的
@connor2003 all of it looks like wireless connections, not ethernet. What model is your computer?
完成的
Hp x360 convertible 15-cr0037wm
完成的
添加一条评论
2个回答
最有帮助的答案
I see a VPN device driver installed. Uninstalling the vpn software should fix the problem.
这个答案有帮助吗?
得分 1
评论:
Disabling it is the farthest I can go (still didn't fix it) Removing it would require entirely reinstall my vpn software.
完成的
You can go into control panel then go network and sharing Center then go to network adapter's and see what it's called when you right click the ethernet adapter and go into properties
完成的
添加一条评论
was this always a problem or is this something recent if so i would try using recovery setting to go back to a restore point if you are using windows 10 use the search bar and type recovery then open system restore follow the prompts and choose a date and time as far back as you can this should reset the setting back this will not effect your files
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Connor 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 7
过去的30天: 23
总计 327
