跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
17585 个问题 查看全部
LCD Lid Back Cover Replacement
I have a late 2013 MacBook Pro Retina. It has a dent in the side of the casing surrounding the LCD. So essentially the LCD lid. I would like to just replace this but cannot find a part number or even the correct part name to call it to refine my search. The LCD functions fine it just has the small dent in it which drives me crazy. See the pic.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
2个回答
已选择的解决方案
Unless you want to replace the full screen assembly you’ll have to live with the dent. Retina screen is firmly glued to the aluminium frame and chances it will break during removal unless you’re a quite experienced refurbisher are very close to 99%.
这个答案有帮助吗?
得分 2
评论:
Agreed. As I said, it's best to take it to a technician.
完成的
添加一条评论
Apple keeps all of their parts and product information under wraps (yes, this even applies to the shells and cases), so you're not going to find anything online without the Dark Web. It's best to take it to a licensed Apple technician to get it repaired, since they are the only ones who can actually manage to acquire parts legally.
Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Patrick Sutton 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 47
