Loud noise during wash cycle
Washing machine is making loud noise during wash cycle but stops during spin cycle. The noise is constant even when the tumbler is not spinning during wash cycle( when changing spin direction)
Cause 1
Pulley
The drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If the drive pulley is damaged or defective, replace it.
Cause 2
Drive Motor
The drive motor bearings might be worn out. Washer motors are normally very quiet during operation. To determine if the washer motor is defective, remove the drive belt from the washer and then run the motor. If the motor is still loud, this indicates that the drive motor is defective and needs to be replaced.
UPDATE 5/15/18
After listening to that it sounds like a bearing to me.
Cause 1
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Cause 2
Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing.
Cause 3
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
这个答案有帮助吗?
Both are in very good condition. I did not test the engine because it doesn’t make any loud noise at the end if the washing program when it just spins.
After inspecting i am thinking maybe is related with the pump or heater ?!
If the tumbler is not spinning at all the noice persists so it couldn’t be the motor. Am I wrong?
That link is unavailable to me.
the link should work now. it was set on private
i made another one with back panel removed: https://youtu.be/fXB806xackE
Hi, now my machine has the same issue - anyone found a way to fix this?
/Lars
made a recording with the sound it makes.
这个答案有帮助吗?
Hello, do you still have this video, and if so would you mind posting a working link. Currently going through the same issues with my Electrolux
Michael, did you find the video, or fixed your washingt machine? I have similar problems now :)
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 48
总计 5,239
