跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone 6 Plus Error 4013 after Screen, Logic, and Lightning replaced
I recently gained possession of an iPhone 6 Plus that I replaced the screen on for a friend. The phone then proceeded to boot loop until it ran out of power. Thinking that the device was fubar, he gave it to me. So I decided to try basically everything. Got to the point that I decided to replace the logic board after having heard that error 4013 can be NAND related. Did that. Still get the exact same error whenever I try to restore it with iTunes.
64GB AT&T Locked iPhone 6 Plus
Parts replaced:
  • Screen
  • Lightning and audio assembly
  • Logic Board
  • 5GHz wireless antenna
Any insight?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
disconnect everything except chargeport and see if it will flash without errors, then if it goes through ok start connecting each component one at a time until you find the culprit.
这个答案有帮助吗?
得分 1
3条评论:
well... seems like the screen was the problem, but that raises a new question... how come a screen that was purchased from iFixit didn't let the phone boot or restore...
完成的
So, that "fixed" it, but now it just boot loops forever again... And I can't test the original screen anymore because it was practically unusable when I replaced it.
完成的
Bad front camera or home button flex from a screen that has preassembled components can cause this.
完成的
添加一条评论
That is Nand issues,Most of the cases you have to reprogram Nand with removing from logic board and reprogram with programmer.
这个答案有帮助吗?
得分 0
1条评论:
The logic board has already been replaced with a known good board. So the issue is no longer NAND related. Also, I was able to get it restored by taking the replaced screen off. So the issue is now with the screen and that it causes a boot loop whenever it’s connected.
完成的
添加一条评论
添加你的答案
John Peters 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 73
