跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Screen change keyboard don't show up
Okay, here is the weird situation.
I changed the screen of an iphone 8, everything works perfect, customer came back, he cannot edit or add contacts because the keyboard wont show, but on everything else keyboard pops up.
Anyone know what this is?
I suspect a software issue since keyboard is showing every where else.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try a hard reset first (See: 如何把iPhone 8 強制重新啟動(如何强制重新启动 iPhone 8 【simplified Chinese】))
However I think you are correct, a software fault is the most likely cause of this and that would be fixed via an update/restore.
Is the customer on the beta program? A friend of mine is and he could only answer incoming calls, his dialer wouldn’t work until the following update was available.
这个答案有帮助吗?
得分 1
2条评论:
Actually thanks for this, but it was me having a mayor brainfart.
I just had to double click the homebutton and exit all programs.
完成的
No worries, if only all fixes were that easy!
完成的
添加一条评论
添加你的答案
nicolay.94 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 60
