跳转到主内容
The Surface Laptop 2 by Microsoft was released October 2018.
18 个问题 查看全部
Screen is damaged internally
Screen doesn’t show physical damage only internal.. How can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
As you can see, in the upper right corner of the screen there is a crack (circled in red) in the liquid crystal layer of the screen, which is most likely causing the horizontal lines going through the LCD. I would send the the laptop to a repair shop for them to fix it for you because the Surface Laptop is very, very difficult (or maybe even impossible!) to open up with out inflicting lots of damage to both the internal components and outer casing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ailyn Gonzalez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,263
