跳转到主内容
Model k52t38 (also known as the Lenovo Vibe K5 Note)—an Android smartphone with a 5.5" display, first released in 2016. Available in Champagne Gold and Platinum Silver.
31 个问题 查看全部
Why my phone isn't charging?
Yesterday my Lenovo vibe k5 note fell in a bucket filled with water just about 2 to 3 cm. My phone get wet till above the speaker and immediately I take it out of the water and use hair dryer to dry it. After when I checked my phone everything is ok, but my phone is not charging above 27% and taking 3 hours 28 minutes to charge till 20% and above that is not charging even I charged my phone full night from 03:47 am to 9:28 am but then also my phone charged only 27% . Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You most likely need a new battery.
这个答案有帮助吗?
得分 0
1条评论:
Or your charging port may have failed, you should also replace that. Right now you should put it in rice to try to draw out most of the water.
完成的
添加一条评论
添加你的答案
Aryan Patney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 482
