跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
461 个问题 查看全部
Is the Display Adhesive Absolutely Necessary?
I have a Galaxy S6 that I use for app development. Recently, I needed to replace the display, but I’m not sure if I need to use all of the provided adhesive, or any at all. From past experience, this adhesive is a mess to remove (especially the copper-colored areas on the back of the panel), and will most likely destroy the display assembly if I ever need it off again.
The phone will spend most of its days on a desk tethered to a computer, so durability isn’t an issue. I’m primarily concerned with future repairability if I ever need to service the charge port, home button, or the rest of the daughterboard assembly. Is it absolutely necessary to use adhesive, or is there any problem with using just the thin adhesive “gasket” around the edge of the glass?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
1 Answer
已选择的解决方案
If it’s not subject to rough handling or liquids, I don’t see why a thin coat would be just fine for your purposes.
这个答案有帮助吗?
按维修分数 2
评论:
It's more like a sticky backing that's been pre-applied to the back of the display. It came with a thin plastic film covering that adhesive, but it looks like I don't have to remove all of it at once.
by
添加一条评论
添加你的答案
nerdyphysicsguy 将永远感激不已
浏览统计数据:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
总计 25
