Power outage on my mac
i had a power outage today and my mini mac went out try to put it on not coming not start ing no light coming on nothing what could be the problem? please help dont want to lost this unit had alot of info on it thanks
Your info is safe on the hard drive. Use a multimeter to test the output of the wall receptacle then plug in the adapter and test it next.
All you will need is a SATA to USB adapter, then plug it into another Mac to access your data:
这个答案有帮助吗?
If you don't have a DVM a cheap outlet checker will do as well like this one: 3-Wire Receptacle Tester
Do make the effort to get a good surge suppressor or better yet a UPS once you get your system running to help protect it.
Okay I check all of that but still not getting Mac mini to work what is my next step to get the Mac mini to work again?
I would like to know how can I get this computer to work again
You are going to have to found out, using a multimeter where the power stops coming in.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 125
