跳转到主内容
Repair manuals and information for the Microsoft Surface book line of laptops.
207 个问题 查看全部
Why isn't my surface book clipboard not charging?
I just bought a surface book from ebay. I let it charge for a few hours while I went to class, when I came back it said Batter 1: 0% and not charging. I’ve tried everything, from resetting to repairing using the surface diagnostic tool. Nothing seems to work. I even tried manually charging the clipboard. But it just won’t charge. If I let the clipboard charge for an hour then it shows 88% and shuts down immediately after I unplug it. When I attach it back to the keyboard it says 88% not charging, 75% not charging, until it reaches 0. The keyboard charges fine, the only problem is with the clipboard.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
If you bought it second hand, go find the seller.
这个答案有帮助吗?
得分 1
添加一条评论
Issues with laptops not charging correctly are usually related to a bad battery, a damaged charging port, or a damaged charging cord. Have you tried exchanging the clipboard’s battery and/or charging cord? This may fix the issue.
这个答案有帮助吗?
得分 1
添加一条评论
It is so common problem, which needs to be solved and fixed. I faced it last month when I was preparing for my classes. I only finished my paper and lost it in a minute, it was the day before the deadline, so I run out of time and needed essay help. That is why I had to ask help from this https://www.aresearchguide.com/essay-hel... project, the paper was great and I got a good mark. But I had to pay money just because I faced this issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hardy Man 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,397
