Es300: Brake and abs lights came on
Brake and abs light in my 2003 es300 came on. I have checked the abs sensors and cleaned them, checked my brake fuid and its alright. And brake application works fine. How do i get rid of these lights?
If you believe there is no problem and you want to reset things disconnect the battery for a few minutes then reconnect. If there is no problem the brake and abs lights will stay off. If it comes back on you may have a problem and get it checked by a mechanic.
这个答案有帮助吗?
Ok. Will try it and revert. Thanks
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 856
