跳转到主内容
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
Ps4 controller acting as if the battery is dead
My gf spilled juice on my ds4 and the triangle and circle buttons were sticking. I decided to take it apart to clean it. After reassembling it, it didn't turn on when I pressed the ps button. When I plug it in it works fine. According to the menu it's connected via Bluetooth. Every function works including the headset. But as soon as I unplug it it dies. Note that it was fully charged prior to disassembly and the juice was spilled on it weeks ago. I used it daily with 100% functionality until I got fed up of the sticky buttons. I've tested the battery and I get 3.6v. The ps4 shows it charges for a few mins then indicates it's full. But it still dies the instant I unplug it. What could be the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论:
I have this issue too when I plug my charger in my controller on the menu it says it’s charging and my mic works but when I unplug my charger my controller dies right away I tried to reset it and everything still I can’t fix this issue
完成的
添加一条评论
8个答案
Worn down battery. Broken charger system? Have you replaced the battery in it?
这个答案有帮助吗?
得分 0
2条评论:
The ps4 and controller were purchased in December. I haven't had a chance to get a new battery yet. But like I said, it was fully charged, tested the battery and got 3.6v, and it works and communicates via Bluetooth, but only if I plug it in. The instant I unplug it it shuts off. It acts as if the battery is not connected.
完成的
Hmmm... damaged PMIC module/power regulator?
完成的
添加一条评论
My Solution is to go to settings and then press devices and then press devices go to controllers the third bar down And then go all the way to the bottom in the controller setting and put the connection to “use USB cable” so that what are you charging your controller with the USB cable instead of a Bluetooth charger.So technically your controller was dead but it showed it was alive because it was on Bluetooth and was charged with a USB so if you never charged with a Bluetooth it was dead if you understand what I mean no solutions to.
这个答案有帮助吗?
得分 0
添加一条评论
Sounds like a new mainboard… hopefully not. But it’s plausible.
这个答案有帮助吗?
得分 0
添加一条评论
can I charge my ps4 controller with a iPhone charger bc every time I try to charge it with a normal one it one charge
这个答案有帮助吗?
得分 0
添加一条评论
That’s a not effective battery so if u have a warrant on it return in my solution is to press the reset button on the back like 6 times if it doesent work than I have no idea cause I still have the same answer
这个答案有帮助吗?
得分 0
添加一条评论
I have an Identical issue and this is what I tried:
- Replacing the power board attachment with ribbon cable.
- Replacing the battery.
- Resetting controller by pressing the button on the back.
I can use it only when it’s connected to the charger or powerbank (Bluetooth works) but once I unplug it controller forgets about being synced and pairing has to be done once again… Any ideas which part on the motherboard should be checked?
这个答案有帮助吗?
得分 0
添加一条评论
Idk
My
Controller
Want
Change
这个答案有帮助吗?
得分 0
添加一条评论
bought brand new controller..5th one this year. used it for a week. now ds4 windows says it is at 100% battery, then at 0% , then at 100%. I cannot even play with the thing plugged in. Tried cable on other 4 controllers. Works. Those controllers all have drift and busted face buttons..
solution : f sony.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joel Schnaier 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 116
总计 14,017
