跳转到主内容
Can a dying PRAM battery cause display and clock issues?
I purchased an iMac G3 a few days ago (for nostalgia reasons) and all seemed fine with it until last night when I booted it up again and the display was offset to the bottom of the frame, making it cut off. It also had these thin, shaking horizontal lines all the way down the display and when it completed booting up, the date and time was reset to 1902, I believe.
I first attempted resetting the PRAM to no success and then booted the iMac command line prompt to reset the NVRAM and the screen seemed fine in that mode. After it restarted, the screen seemed perfect again for a few minutes until the screen went offset again and the lines return. (The clock did not reset this time)
What could possibly have caused this and how can I fix it?
My theory so far is that it’s a result of the iMac being left unplugged for an extended period of time and has affected the PRAM battery somehow as that would explain the reset on the time and date. Would that also affect the display though?
Picture attached to show the horizontal lines and display alignment.
UPDATE: I left it on for half an hour this morning and the display keeps alternating between working normally and the offset resolution with the shaking lines again. Each switch lasting a couple minutes before going back to the other. Could this still be the PRAM still or would it be more graphics related?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The PRAM battery keeps your clock ticking! So yes a dead battery will cause it to lose the date & time.
Your display issue is more inline with old components in the display video circuitry. The electrolytic capacitors degrade over time and your system might have Capacitor Plague.
Do be careful! CRT circuits are high voltage and even when you turn the system off and unplug it the caps and CRT are still holding some serious power!
这个答案有帮助吗?
得分 2
1条评论:
This model uses a 3.5 volt Lithium 1/2 AA battery. https://www.newark.com/lascar/batt-3v6/l...
完成的
添加一条评论
添加你的答案
Lia Tomlinson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 11
总计 436
