跳转到主内容
The Canon Rebel T6i is a popular, semi-professional grade Camera designed for any user. This guide is meant to aid in the repair of a few common problems that may occur during normal use.
25 个问题 查看全部
Date and time doesn't save after changing battery in Canon 750d
Hi,
Each time I replace the battery in Canon 750d, a screen appears asking for a date and time. The time settings are not saved in the camera when it is without a battery. Why does this happen and how can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you find the solution? I have same problem with my Canon 750D. Please help
完成的
添加一条评论
1个答案
已选择的解决方案
Hi
Unfortunately it appears as though the camera has no inbuilt backup battery (or capacitor) to maintain the date, time and zone settings when the main battery is removed.
According to the user manual on p.43, the date, time and zone will be reset :
If the camera is stored without a battery
When the camera’s battery becomes exhausted
When the camera is exposed to below freezing temperatures for a prolonged period.
It seems that you have to put up with it doing this.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Roni Aviv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 862
