跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
battery problems with my MacBook Pro
I got a problem I need to keep charging my computer the battery dies around 30 minutes but when it charges it takes quick second to fully charge?
Do I need a new battery ?
or something else is going on because I went to Apple Store it says the battery is in good condition.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It could be a weak charger or charging port. Before you do anything, you show check the maximum battery compacity.
Hold the Option key and click the Apple () menu. Choose System Information.
  1. Under the Hardware section of the System Information window, select Power. The current cycle count is listed under the BatteryInformation section.
If it says your max battery compacity is under 89%, looks like it’s time for a new battery. IF it’s above that you should be good. It’s gotta be something more internal with your Mac or it’s a bad charger.
Update (05/02/2019)
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery There could be other batteries on amazon and eBay that could be cheaper but this is for the highest quality. Please hit accept answer. It would mean a lot and best of luck!!!!
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery图片
产品
$89.99
这个答案有帮助吗?
得分 1
4条评论:
thank you for the great help Ian .
i did what you ask and i see Cycle Count: 47 and you are right i need a new battery .
and one more thing what is the name of the battery to change it?
and thank you Ian.
完成的
I recommend this great free app! CoconutBattery
完成的
@ianshalongo - I don't see enough information here to jump on to replacing the battery yet.
If you want to give John some guidance on the MagSafe charger as we have seen a fair amount of bad chargers (Fakes) or the charger is worn out (cable & connector).
I would review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters and this article OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth as well as review this vid YouTube - Real vs Fake MagSafe 2 Charger Macbook Pro
完成的
i know that and will do Ian and thank you and no problem i will give you a negative review lol
完成的
添加一条评论
最有帮助的答案
As @danj mentioned it would be advisable to download Coconut Battery, take a couple of screenshots with battery charging/discharging and add them to your original question. If the store said the battery is in good condition let's give them credit.. it would be a good idea to pinpoint the issue before possibly wasting money on a potentially useless battery replacement. Just 47 charging cycles indicate an almost new battery.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 148
