Looking for suggestions on how to remove the button from the case
As the question title states, I’m looking for suggestions on how to remove the button from the case of a Moto 360 2nd Gen (42mm). I’ve tried tweezers (both a friend’s iFixit set and a professional phone repair place; end result was tweezers bent, and button didn’t budge), fine tip flat tip screwdriver (no dice). Anyone have any suggestions on where to find the 6 lug spanner/spindle nut (not sure of what it’s called exactly) that fits the button, or anything that might grip it snugly enough to back out the button? My inability to back out the button is holding me up from replacing the battery. Thanks. :)
2条评论
Colleagues! I would be grateful for your experience on how to return this button to its place! These six pins on the ring should fall into place. But how to achieve this?
由 Alex Dreg 完成的
I’m having the same issue as the original question. I my button also seems to be jammed. I tried heating it up with a lighter to loosen up the screw, and even a drop of WD-40. Still does not budge. The tweezer that came with the set does nothing. Any help would be much appreciated.
由 Greg Perpignan 完成的
