跳转到主内容
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1189 个问题 查看全部
Laptop wont turn on only with cable after clean up intern
Hello you guys,
today i bought 2 laptops acers aspire E 17
since they where a little bit old and i want to at a ram memory and an ssd to make the pc go a little bit faster , my laptops wont turn on anymore.
first i opend 1 laptop to clean up inside. and after cleaning up and replace the logic board back in place, the laptop only starts up with an cable. i taught that i might damaged something first, like the battery.
now i opend the other laptop and place that battery in to th broken one to test, but it did not work.. i replaced the battery in the working one and now the both laptops have the same problems… what can this be???
is it like you are not able to take the battery out or what did i do wrong??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If both laptops were working before they were opened, then they may have been damaged by electrostatic discharge (ESD). This could have occurred if you did not use an anti-static bracelet or anti-static gloves before servicing the laptops. ESD can cause microscopic, yet significant, damage to a motherboard.
这个答案有帮助吗?
得分 0
1条评论:
I found it myself....
I never saw that before ever in my life,
There is a small button on the motherboard that needs to be pushed in before you can start your pc...
It only can be pushed in when the keyboard is replaced and screws are in the holes...
Feel so stopid
完成的
添加一条评论
添加你的答案
glennjacobs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
