How to unbend aluminum from on screen corner?
I dropped my laptop and the corner of the metal frame bent into the laptop and is slowly pulling the laptop apart.
I just did this to my xps 13. The hinge could not open all the way. All I needed to fix it was to open the laptop slightly, wedge a smooth flathead screwdriver between the two metal covers (top/bottom) near where they contact and gently pry against the bent section to unbend it. The metal is VERY soft and did not take much effort. I used my forearm to push against the hinge to support it while I did this and there was no damage to the hinge.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 658
Can you post some pics so we can see the area and the where the system is not lining up. 在已经存在的问题里加入图片
由 Dan 完成的
