跳转到主内容
Only works when plugged into a charger?
So this morning I was shaking my iPod for the shuffle to work. I guess I shook it too hard because it shut off and will only work if plugged into a charger. It works just fine and seems as if nothing is wrong, but once you unplug it it turns right off. It's done this once before, but it fixed right away. Not fixing this time. What would be the best thing to do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
follow the steps in the battery replacement guide iPod Nano 4th Generation Battery Replacement to get to the battery. you will notice that the battery is attached using solder points. check to see if they are solid or if any other cables are loose during disassembly.
Good luck.
这个答案有帮助吗?
得分 2
1条评论:
It is possible but hard to do mine almost caught fire !!!!
完成的
添加一条评论
添加你的答案
wafflesfasher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,510
